June 26, 20197 yr I'm seeing a resizing/refreshing issue with Enpass when switching screen resolution sizes which makes the tool unusable (until I kill app and restart app). See screenshot. Here is the scenario: I have my MacBook Pro (15-inch, 2017) plugged into a 1440p monitor, when I unplug and go back to mac laptop (1920x1200) enpass looks like the screen shot. The only way to recover, is to kill the app through Activity Monitor and restart Enpass App. Enpass Beta 6.1.0 (431) MacBook Pro (15-inch, 2017) Apologize if this isn't the correct forum, I didn't find an issue tracker.
June 26, 20197 yr This issue has been covered elsewhere on the forum, the search box will help you find the other threads on the issue.
June 27, 20197 yr Hi @venamis, Sorry for the trouble you are going through. This issue has been fixed and beta update with the fixes will be available by the end of next week. Thanks for your co-operation.
