July 14, 20197 yr Hello, my name is sponk and after searching a longer time for a password manager which is able to use my owncloud i came to enpass. I installed it on my windows 10 desktop and laptop - it works well. Now i wanted it to install on my linux mint 18.2 64 bit desktop too. I followed the website "...enpass.io/support/how-to-install-enpass-on-linux" and i thaught that everything was allright. After exit the terminal, i tried to start enpass setup, but nothing happend after doubleklick on the icon. I restarted the system, I deinstalled enpass an installed a second time with the same result. What´s going wrong? What can I do? Please help me. sponk from austria
July 14, 20197 yr If you try to start it from the command line are there any error messages generated?
July 17, 20197 yr Author Thanks for your help, i filled in the command from the launcher "opt/enpass/Enpass %U" in the terminal. The result was the message: "/opt/enpass/Enpass: error while loading shared libraries: libcurl.so.4: cannot open shared object file: No such file or directory" I dont´t know what to do now. Pleas help me. sponk
July 17, 20197 yr Author Hello everybody, i´ve got it... after installing libcurl package 3 everything is okay. Special Thanks to Dentonthebear sponk
