July 21, 20197 yr Hello, i use enpass on my mobil via app. Is it possible to print an overview of all my passwords? best regards Matthias
July 22, 20197 yr Hi @matthias-2019, Thanks for writing in. In the desktop version of Enpass have the Print feature. You can check under the ≡ menu from the toolbar --> select File →Print. Hope this helps!
