August 24, 20197 yr I use Authy on my phone to generate TOTP codes. I turned on 2FA in my Nextcloud account. As expected, Enpass (on my Mac) is no longer able to sync. I checked Nextcloud support. They said to use "app passwords". Allegedly you go into the preferences for the application that you want to sync, and there is a place to enter an app password. https://help.nextcloud.com/t/two-factor-authentication-totp/52347 I couldn't find this in Enpass. How do I sync my database with a copy stored on a Nextcloud server that has TOTP 2FA enabled?
October 15, 20197 yr I'm currently in the same situation. Did you figure out a solution for yourself?
November 18, 20196 yr You need to create an application password from inside nextcloud. Go to settings -> security -> devices & sessions and create a new one. Copy the generated password and reconfigure your Enpass nextcloud settings using the app password instead of the login credentials.
