August 30, 20197 yr Dear support, Since some time (about a week or so), the autosave feature stopped to work for no obvious reason (at least for me). Namely, for instance, when I put in my login and password at Steam (https://store.steampowered.com/) the application does not propose to save it in Enpass (though it is not present there). I tried to reinstall the extension, didn't help. Here are the software I am using: MacOS 10.14.6 (18G87), Firefox 68.0.2 64bit, Adguard 2.1.2.595, Enpass 6.1.3 (420). Before this happened, everything was pretty smoothly. Looking forward to your suggestions. Edited August 30, 20197 yr by flittingstone added extra information
August 30, 20197 yr Hello @flittingstone, Thanks for using Enpass. It's annoying to see that auto-save feature is not working smoothly and we'll be happy to help! While we are reproducing the issue at our end, we'd recommend you to try disabling "Adguard" temporarily and try re-entering the login information. Make sure that Enpass application is running in the background. We'll let you know as soon as we have an update. Thanks.
August 30, 20197 yr Author Hi Kashish, It seems that the problem was due to the Firefox extension ScriptSafe. As soon as it was disabled, the auto-save feature resumed working fine. Thanks.
