September 20, 20197 yr Could you please add Auto or System default mode for theme, so the app can follow theme currently set in the system? This way it will be possible to use light/dark theme automatically depending on the theme in the system itself.
July 18, 20224 yr Hi @sviperz and @renz, Thank you for reaching out to us. I have duly noted your feedback and it has been forwarded to our concerned team for further consideration. #SI-2993
July 19, 20224 yr @sviperz, @renz, Our backend team informed me that this feature has been implemented in our recent updates. Please upgrade the Enpass app to its latest version and let me know what you find. Refer to this link.
March 29, 20251 yr Howdy! I'm a linux user and was hoping we could also have this feature utilize dbus? $ dbus-send --session --print-reply=literal --reply-timeout=1000 --dest=org.freedesktop.portal.Desktop /org/freedesktop/portal/desktop org.freedesktop.portal.Settings.Read string:'org.freedesktop.appearance' string:'color-scheme' variant variant uint32 0 discussed here: https://gitlab.gnome.org/GNOME/xdg-desktop-portal-gnome/-/issues/46 This page discusses the options provided by 0, 1, and 2. I believe this is the going standard as freedesktop.org seems to be the standard/implemented everywhere and provides a specification. My request is that the app enpass if configured to use a auto theme, switch between light and dark mode. Most importantly it doesn't require restarting the application to enforce a new mode. I believe this feature is already available on other platforms. TIA! Love your app ❤️
