September 23, 20197 yr Hello, early in the morning I updated my Safari Browser to Version 13, but now I can't find the Enpass extension. How to reactivate it?
September 30, 20197 yr Hi, the same problem here in the extension manager the entry is present but in the safari is not displayed! MacOS 10.14.6 Safari 13.0.1 Enpass 6.2.0 what can I do ? thx Mario
September 30, 20197 yr Hey @JayTee and @zariomahn, Thanks for using Enpass. Did you try enabling Enpass Safari extension in Safari preferences? Please confirm. If already enabled, try disabling and re-enabling the extension. Thanks.
October 1, 20197 yr Hi, thanks, I once uninstalled the extension and then reinstalled, now everything works. Thank you very much Best regards
October 1, 20197 yr Hello @zariomahn, That's surprising. Are you facing the same issue with other browsers too? Please check and confirm. If the problem still persists, please run lsof -i:10391 command in the terminal and share the output via support@enpass.io. 10391 is the port number here. Thanks!
October 16, 20197 yr Hello Kashish, yes the same problem to me with firefox and opera browser. Catalina Version I tried lsof... but The default interactive shell is now zsh. To update your account to use zsh, please run `chsh -s /bin/zsh`. For more details, please visit https://support.apple.com/kb/HT208050. Peters-MacBook-Air-2:~ peter$ lsof -i:10391 COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME Enpass 15554 peter 20u IPv4 0x3519d6b4a400b3a3 0t0 TCP localhost:10391 (LISTEN) Enpass 15554 peter 31u IPv4 0x3519d6b4a58e3e23 0t0 TCP localhost:10391->localhost:53773 (CLOSE_WAIT) firefox 37933 peter 26u IPv4 0x3519d6b4a95919e3 0t0 TCP localhost:50602->localhost:10391 (SYN_SENT) firefox 37933 peter 89u IPv4 0x3519d6b4a59a4ca3 0t0 TCP localhost:50603->localhost:10391 (SYN_SENT) firefox 37933 peter 127u IPv4 0x3519d6b4a45063a3 0t0 TCP localhost:50615->localhost:10391 (SYN_SENT) firefox 37933 peter 131u IPv4 0x3519d6b4a5968723 0t0 TCP localhost:50618->localhost:10391 (SYN_SENT) Peters-MacBook-Air-2:~ peter$ After changing the shell COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME Enpass 15554 peter 20u IPv4 0x3519d6b4a400b3a3 0t0 TCP localhost:10391 (LISTEN) Enpass 15554 peter 31u IPv4 0x3519d6b4a58e3e23 0t0 TCP localhost:10391->localhost:53773 (CLOSE_WAIT) firefox 37933 peter 89u IPv4 0x3519d6b4abe01e23 0t0 TCP localhost:50811->localhost:10391 (SYN_SENT) firefox 37933 peter 90u IPv4 0x3519d6b4a654a463 0t0 TCP localhost:50813->localhost:10391 (SYN_SENT)
