Click tray icon to open Enpass UI
Wish I can simply open the UI by clicking on the tray icon.
But instead I have to right-click tray icon, click Restore, click a down arrow, then click Show Enpass.  Too many nested clicks!
Hi @jakejohn,
Thanks for your suggestion. I would like to share that in Traditional Windows App single click on tray icon will open Enpass helper window (the one you see with extension) , while the double click will open the main Enpass app. For other platforms (Linux, Mac) same is already on our roadmap for the future version.
Cheers!
@Anshu Kumar,
I noticed if the main application is minimized to the task bar, double-clicking the tray icon does not bring the main application to focus.
Thank you.
Hi @jakejohn,
Thanks for writing back.
Actually, it's the default behavior of App. You have to manually click on the Enpass icon (In Task bar) to bring the main application to focus. However, I have noted down our discussion for improvement.
Cheers!
