March 23, 20179 yr Hello, in KeePass I have a very large database (2462 entries). But 70% of them don't have a password (just are bookmarks). So please add a checkbox "Only import entries that contain passwords". In KeePass I have many folders and subfolders, so I would just start importing one folder an then continue with the next folder. Now I have to export one single folder from KeePass, import it in Enpass and then continue with the next folder. It would be easier when you show a tree view of my KeePass folder structure and let me select single folders that should be imported. This way I just nee to to the export ONCE and then I can import folder by folder. Regards OLLI Edited March 23, 20179 yr by OLLI_S
March 23, 20179 yr Author Hello, additional suggestion for the KeePass import: After importing some data from KeePass I see a message that the KeePass XML file should be deleted (because it is not encrypted). You should offer a button that securely deletes the KeePass XML (by overwriting it). This is just one mouse click for the user instead of many user-actions (when he has to open the explorer, search for the XML file and the has to delete it. So this feature increases the usability of Enpass (I work as Usability Engineer). Regards OLLI
