Importing from .csv does not put "Title" in correct field
When importing from a .csv file it brings everything in, but instead of using the "Title" column from the .csv file it leaves the title in enpass blank(where it says "Add Title"), and adds an Additional Details section and a new field for "Title". Everything I've tried gets the same results.  I also can't find any automated way to add the new additional Title field to the top Title area(next to the icon).
I'm importing using the Login category.
Any help would be appreciated.
Thank you!
