October 20, 20197 yr Hi, I'm using Enpass on Windows 10 (latest updates), my default browser is Vivaldi (with the Enpass extension installed). From time to time the iCloud authorisation runs out (due to time limitation?) and has to be renewed. This doesn't work for me, when I just do the un-sync / re-sync thing. The app gets stuck with a loading animation. Then I remembered that the sync button is supposed to open a website in the default browser. I switched from Vivaldi back to Edge and it worked. After that I can switch back and everything's fine. Is this a bug?
January 10, 20206 yr Same here, except I don't have Edge on my work PC so for me, iCloud now doesn't work at all. What happens is it opens to apple-cloudkit.com, that asks me to log in, which I do (including 2 factor auth), then it asks for permission to open enPass - which I allow - and then the webpage and enPass both just sit there doing nothing. Tried using Chrome and IE. Incidentally this works fine on my Linux machine. Edited January 10, 20206 yr by Netizensmith
January 10, 20206 yr Hi@Netizensmith, Sorry for the trouble you are going through. Please let us know when you click on the link to open Enpass does it get open in the foreground? If no, then please copy the URL from the browser and open Enpass manually Hope this helps!
