November 11, 20196 yr Hi, For work, I often connect my laptop to the networks of companies that block connections to Google Drive, Dropbox, etc (to avoid data theft). The problem is that some of them also log blocked attempts and may temporary suspend my proxy account. At the moment, to prevent unsuccessful connections from Enpass, I set a fake proxy (such as "127.0.0.1:1234") so I can use Enpass "offline" (in it I have the credentials of many network devices that I manage). Then, when I connect to an "open" network, I remove the fake proxy and Enpass uses the system proxy to sync. It would be nice to have a menu like "File -> Pause syncing/Resume syncing" or "File -> Go offline/Go online", so pausing synchronization would be a breeze. Spotify has this feature and is very convenient. Thanks
February 16, 20206 yr Yes, please a offline modus! I use webdav just in a local setting. I had to turn off mobile data on my iPhone. This is stupid. Just add the possibility to pause sync. Otherwise enpass is great.
February 17, 20206 yr Hi @lammoth, @Nasendackel, Thanks for the feedback. I have shared the same with the concerned team for further implementation. We appreciate the feedback as it helps us to create a better product.
