November 15, 20197 yr A lot of times, when entering my master password to unlock Enpass, I use the wrong password but quickly figure it out. I can't seem to use the keyboard shortcut Ctrl-A to select all of the characters and hit delete to quickly delete what I had entered. It is cumbersome to delete all of the characters by delete key or just enter and re-enter the correct password.
March 9, 20206 yr Same here! I thought that this was once possible. Would be great if the bug could be fixed or if the feature could be implemented.
March 17, 20206 yr Hi @John Deere & @Criall, Thanks for using Enpass and writing to us. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
October 10, 20206 yr Are there any news about this yet? I'd also like to be able to use CTRL + A if I make a mistake when typing my master password. Especially with a long master password this would be helpful. Unfortunately this thread is almost one year old and the last answer was 7 months ago.
October 12, 20206 yr Hi @SVM, Thanks for using Enpass and writing to us. The suggestion is in our roadmap for the future and hopefully it might be available in upcoming updates.
