November 22, 20197 yr I have a pretty dumb question. Can you please suggest to me where I can found the Dark Mode for the Mac Version? Same Stuff on my iOS Device. Is it possible that the Dark Mode would not be present on Apple Devices?
November 24, 20197 yr As i know, the Dark Mode will be activated automatically when it is set to the device himself. Means that you have to activate the Dark Mode in macOS System Preferences.Same on iOS Device. Then Enpass shows the Dark Mode. It would be nice if the Dark Mode cold be activated even when in the macOS System the Light mode is active. Edited November 24, 20197 yr by macudo
November 25, 20197 yr Author Thanks. i wrote about Dark Mode, but it is the Dark Theme that isn' t present on my Apple Devices. Maybe it must be so.
November 25, 20197 yr In the Apple Devices you have to set the Dark Mode in the Control Center. Dark Mode on Apple Devices is available in iOS 13. If you have activated it on the Device, Enpass will start automatically with the Dark Theme. https://www.howtogeek.com/440078/how-to-enable-dark-mode-on-your-iphone-and-ipad/ Edited November 25, 20197 yr by macudo
November 26, 20197 yr Author Thanks. My Device has only iOS 12 and therefor I didn't found it. And Maybe same stuff on my iMAC with High Sierra.
