November 24, 20197 yr Hi, I just migrated from 1password. You are just like 1Password was years ago, please do not start to kill features like 1password did over the years. OK so what we need is to able to edit an Entry directl from the browser plugin. The reason is coming from 1password it generated a lot of old passwords and they are all shown in enpass and it is hard to get rid of the old invald entries like it is now.
December 18, 20196 yr Author ya please some edit button please. Its mostly a sername you have to add or change the name of the entry, should be possible inside browser plugin.
March 26, 20206 yr +1 to this. Related to this, if I'm using the browser ext, and I type in some text to filter the list. I might decide then the entry shown needs editing. The only way to do this is to go to the system tray, open the full Enpass app. Then, that app has no idea what I was showing in the browser so I have to type in the filter text again to find the relevant entry. Finally I can edit it. Adding some shortcut to this process would be welcome.
March 26, 20206 yr Hi All. Thanks for using Enpass and writing to us. I am glad to share that you guys can also change the details saved in Enpass from the browser plugin/Enpass extension. To do so, please enable 'Ask to save new logins' from the 'Browser Settings' of Enpass. Thanks.
March 26, 20206 yr Garima, sorry but that's not the same thing. Yes I already have that set and yes I can save new entries. No doubt if I submit a page where I have updated the details to what is in Enpass, it will prompt to save the new details. But we really want a direct link to editing the details stored in Enpass.
March 27, 20206 yr Hi @ddken, Thanks for writing back. I really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the development team for further consideration. Thanks for the suggestion!
January 8, 20215 yr hello garima, thanks for forwarding the suggestion. did you get any feedback? will it be implemented? enpass is really great, but every time i have to update, correct or delete an entry, i really miss this feature. no in-place editing needed. only an "edit in enpass" menu entry. thanks, oskar Edited January 8, 20215 yr by oaks
January 13, 20215 yr Hey @oaks Thanks for letting us know that you would like to see support for the same. Significant user demand is a big factor that determines our priorities for new features. The request of this feature has been noted again and shared with the team.
January 22, 20215 yr Hi All, An updated version of Enpass will be released soon in which we've added this feature. Please stay tuned for the new update and let us know if you face any problem after the updated version. Thanks for the co-operation..
January 26, 20215 yr Just tried 6.6.0. You have indeed added an ability to edit the item directly in the browser, but although that looks useful, there should still be an option to open the full editor. So in the browser when you view an entry, which shows as a dialog box, there is now a pencil icon which makes the fields in that dialog box editable. The first time I tried this I thought, I really should make this entry a Favorite. So I hit edit. There I can edit the fields but there is no Favorite star I can click. If I could just launch the full editor, I would have that option. The full editor would also be useful sometimes as the dialog box is rather small. So what you have added is great for some edits. Just add another button to open the full editor. I would suggest that when I click the pencil in the dialog to go into edit mode, beside the word Save, add another pencil or similar to switch from dialog editing to the full editor. Edited January 26, 20215 yr by ddken
January 27, 20215 yr Hey @ddken Thank you for reaching out about this. Also, I have noted your above request and shared this suggestion with the concerned team.
