December 2, 20196 yr How do I save my passwords in another format, say Excel or Word, and/or make a printout?
December 18, 20196 yr Hi @Rolllex Menu (three horizontal lines top right-hand corner) > File > Print > Change the option from the drop down menu to suit > Print > Enter vault master password > press Print > select your output method, I would suggest using PDF if you have the option.
December 18, 20196 yr Author There is no menu top right hand corner. There is a menu to the left, but nothing there similar to "<file<print" etc. I tried both on the PC and on the cellphone, Android. Besides, my version is in Swedish, although I probably can figure that out...
December 19, 20196 yr Author As I said, it doesnt look like that, not in my cellphone, not on my PC screen (Chrome). No such menu. Top left I have the three lines, but no print option to find there. To the right of the three lines the word "Taggar" (Tags, I guess). Nothing more. I have OnePass version 6.3.2.283, Android.
