Dropbox sync won't reconnect after trying iCloud
I was using Dropbox to sync my devices. I just upgraded my iCloud storage and attempted to sync with iCloud. However, syncing with iCloud on 2 different Windows 10 PCs never stops and doesn't properly sync. So, I am trying to switch back to sync with Dropbox. I had no issues reconnecting Dropbox on Windows 10. However, I can't get Dropbox to link with Enpass. After I enter my Dropbox credentials it just displays a spinning processing circle. If I open the link directly in Safari it works fine, but it doesn't carry over to the Enpass app. I have also tried uninstalling and re-installing the app. No luck. Thank you, in advance.
iPhone 11 Pro
iOS 13.2.3
Enpass version 6.3.1
FIX: This issue has been resolved
Go to Safari settings in iOS. Clear History and Website Data. Go back to Enpass and connect Dropbox. This worked for me.
