May 31, 20178 yr Hello, Please add the option to add bookmarks to your product. An old post mentions there are cross browser plugins for this. Unfortunately the programs i have looked at so far all require online accounts...and using your product for the offline database feature, defeats that point. If you believe there are some good cross browser bookmark products, please give some examples that I can install while completely offline, and never get synced with a server. I am trying to move from Roboform to your product. Having Bookmarks all in the same product is one less thing to install....and makes things very convenient when switching browsers because a website isn't behaving in chrome. Plus when i eventually sync to a USB drive, while on the road, it will be nice to have all my bookmarks come along. I can create a tag or folder called bookmarks as a work around....but it is very clumsy. thanks
May 25, 20224 yr I for one would love this option! I'm tired of manually exporting and importing bookmarks between browsers.
May 26, 20224 yr i also requested this a long time ago but i was being told to create tag in enpass and save websites using that instead of having a simple button in enpass option to bookmark a page with just a single click.
May 26, 20224 yr HI @All, Thank you for reaching out to us. I have duly noted your feedback and your suggestion has been forwarded to the concerned team for further consideration. #SI-2868
