May 19, 201610 yr 5 hours ago, Gil said: Just downloaded EnPass but it won't let me sync to icloud. it's not an option. I can find Icloud under the sync option. Please note it, that if I'm not wrong, then iCloud is only available under OSX and iOS.
May 20, 201610 yr Hi Guys, Currently iCloud sync is supported only in Apple Devices. So if you are using Enpass in other platform then please choose another available cloud options to sync. For more details please go through the given link: https://www.enpass.io/docs/desktop-windows/synctime.html#supported-clouds
October 5, 201610 yr Anshu, You said iCloud sync is ONLY supported for iOS devices. However, the desktop version doesn't give you iCloud option either. If I want to use iCloud as my main destination to sync both iOS and desktop then how do I do that? You can't use Dropbox on the desktop version and use iCloud on the iOS version. If I make a change or add something on my Mac (sync with Dropbox) and my iPhone is using iCloud to sync my stuff then how do you expect me to see the change?
October 6, 201610 yr Hi @guyguy16 18 hours ago, guyguy16 said: However, the desktop version doesn't give you iCloud option either. If I want to use iCloud as my main destination to sync both iOS and desktop then how do I do that? As you said, I have a Mac running El Capitan, I would like to let you know, Enpass for MAC can be downloaded from two places: MAC App store and Enpass website. iCloud sync supported only with the version downloaded from the App store. For more details please have a look here. Cheers!
November 3, 201610 yr Hi @My1, Thanks for writing in. iCloud sync for other platform is already in our roadmap but I can't assure any ETA for this and only can say that it will be available in future versions. Cheers!
November 3, 201610 yr well I wasnt asking about when we will see it, I was just curious why it isnt possible yet.
December 2, 20169 yr Hi Ho, same problem here. I live in both Worlds.....Apple and Microsoft and i choose the iCloud for syncing enpass in iPhones, iPads and MAC. But my Windows PC is locked out :-( You say "...available in future versions.." that sounds that we have to wait a few years.... I thought i can avoid 1Password :-(
December 7, 20169 yr well I made myself a box account to have my passwords as far away from anything other personal. sadly box doesnt do a standard TOTP 2 factor (well apple doesnt either) they just do SMS but well better then nothing and I prefer having my PWDB somewhere else then my general use cloud.
May 21, 20179 yr Hi guys, I am using the Apple eco system (iOS macOS) as well as windows. I want to use iCloud Drive as my cloud service. How can I setup Enpass for windows (purchased it in the windows store) to use iCloud (it is installed)? Thanks, Martin
