January 9, 20206 yr I've been using enpass now for a few years, windows, MacOS, Linux, and not sure how or when cause I don't use my mac too often but I have now have to sync files, "sync_default.walletx" and "vault.enpassdbsync" Unbuntu 18.0.4 is syncing enpass to "sync_default.walletx" and MacOS (Mohave) is syncing to "vault.enpassdbsync" Would someone know why, and is there a way to reliably merge them? Sorry a bit more information I should have included, this is all webdav via owncloud. MacOS is EP version 6.3.3, Ubuntu EP version 2.4.1, QT 5.9.5 Thanks Edited January 9, 20206 yr by yerled
January 9, 20206 yr Hi @yerled, Since you are using Enpass 6 on Mac and Enpass 5 on Linux, both are based on a different architecture so you seeing two different files on your cloud. So, to test the sync functionality, you’d need to install the Enpass 6 on your Linux as well. Also, have a look at this FAQ to restore Enpass 5 data into Enpass 6. Thanks!
