July 17, 20179 yr I've recently migrated from Keepass. One thing I miss is the ability to copy a password to clipboard using CMD+C... any chance this could be added in a future version? Thanks for all your work on Enpass. Edit: I've just found this post and the list of supported shortcuts: Quote To Copy Username --> Ctrl+Shift+U To Copy Password --> Ctrl+Shift+P To Copy URL --> Ctrl+Shift+R To Copy TOTP --> Ctrl+Shift+T To launch URL --> Ctrl+Shift +L Perhaps you could introduce a way to make these customisable, in future? Edited July 17, 20179 yr by doctypedigital Updating with search results
July 18, 20179 yr Hi @doctypedigital Thanks for sharing your views. I have penned down your suggestion. Cheers!
January 9, 20188 yr I'm missing this feature too. Standard copy shortcut should copy the password to the clipboard.
