Sync Error 504401 with Onedrive
I found this answer which basically says to disconnect sync and then set it up again and it worked for me.
https://www.enpass.io/support/kb/sync/i-am-getting-error-while-sync-what-can-i-do/
For quick troubleshooting please disconnect the sync and reconnect. If the problem persists please let us know the following details so that we can investigate where the problem could be.
  • Does the Date and Time setting set to automatic on all devices?
  • Does the last synced time get updated on the sync page?
Hope this helps!
