Delete Folder
Hello,
I'm using Enpass for a few days. I have some questions:
1. How can I delete a newly created folder?
2. How can I move an entry from a folder back into the default topics like "login"?
Best regards
Hi @Morpheus
Thanks for using Enpass!
Select the desired folder which you want to delete and Right click on the folder and you will see options to edit and delete the folder. For more details please check out our user manual.
I would like to share that when you create any item, it will be saved in its respective category and will also be displayed under All items. And when you add any item to a particular folder, it is actually not being moved but Enpass creates a reference for that particular item in the folder, leaving the item in the category. Removing the items for the folder will not remove them from Enpass keychain but only that reference will be removed.
Hope this helps!
