Touch ID for Mac as default setting
Hello. I've moved from 1password recently and enpass is really great and worth buying.
However, I'm a little bit uncomfortable with the initial logging feature.
When I launch enpass application on Mac, I can only use 'touch id' after logging in to the application typing my password.
Are there any ways to set 'touch id' as default to run the application initially?
If not, do you have any plans to support this? or is it impossible due to certain reasons such as security?
Hi @wekadi
Welcome to Enpass family!
Currently, Enpass doesn't support full-time Touch ID on MacBook Pro, you have to enter the master password only once when you start the app (unless the device is rebooted/ App is closed), but improving this feature is already on our roadmap for future versions.
Stay connected!
