July 25, 20179 yr Hi, i'm unable to connect to my macOS Server WebDav folder. I've set up my a macOS Server 5.3.1 and setup a folder in /Users/Shared/password/ as a shared folder with WebDav Access Option. The Access is enabled with an Open Direcory User. It works fine when synced from a macOS Client. On iOS i get an error message "Autorisierung fehlgeschlagen. Überprüfen Sie Ihren Benutzernamen und Passwort" ("Authorisation failed. Check your username and password") When i try to connect to the WebDav folder i use the following URL: 192.168.0.10/webdav/password The apache error.log shows the following error: [Tue Jul 25 18:36:29.813703 2017] [auth_digest_apple:error] [pid 3301] [client 127.0.0.1:51401] AH01781: client used wrong authentication scheme `Basic': /webdav//webdav/password/ Syncing from Linux and Windows has another interesting problem: When i try to restore from a fresh installed enpass the webdav sync error says: "There are no Enpass Data on WebDAV..." Best regards Christian
July 26, 20179 yr Hi @Christian Schild Sorry to hear about the trouble you are facing. 13 hours ago, Christian Schild said: On iOS i get an error message "Autorisierung fehlgeschlagen. Überprüfen Sie Ihren Benutzernamen und Passwort" ("Authorisation failed. Check your username and password") When i try to connect to the WebDav folder i use the following URL: 192.168.0.10/webdav/password The apache error.log shows the following error: [Tue Jul 25 18:36:29.813703 2017] [auth_digest_apple:error] [pid 3301] [client 127.0.0.1:51401] AH01781: client used wrong authentication scheme `Basic': /webdav//webdav/password/ Currently, in iOS devices, Enpass uses the Basic authentication scheme to connect with WebDAV instead of Digest. However, we do have plans to improve WebDAV sync functionality in the next major update (Enpass 6). 13 hours ago, Christian Schild said: Syncing from Linux and Windows has another interesting problem: When i try to restore from a fresh installed enpass the webdav sync error says: "There are no Enpass Data on WebDAV..." Please make sure you are using the correct path (Same as you are using on Mac) while restoring the database on Windows and Linux systems. Please let me know if the problem still persists.
July 27, 20179 yr Author On Windows I had to use https:/192.168.0.10/password. 192.168.0.10/password does not work. Maybe this was my problem. With iOS i will try some settings this weekend. If I succeed I will write how I managed to access a macOS server over webDAV with Enpass. Otherwise I will wait for Version 6. Thanks for reply.
