February 12, 20206 yr I am using Enpass across my desktop and my Android phone (I have a paid subsciption). I have just noticed that the 2 versions are registered to different e-mails but sync to the same cloud account. Not quite sure how this is possible but my question is- If I change the e-mail on my desktop version to the email registered on the "paid version" (phone) will my data still sync properly across both devices?? Thanks
February 12, 20206 yr Dear SWFD, the sync of the vaults is independent from the licence. This are two complete different things. You have to enter your Email, if you install Enpass on a new device. But the sync depends of the cloud solution you use for you vault: Dopbox, etc. You could share a (extra) vault not only with your devices rather you could share it with friends and other people, if you want and need to. They don't need the same licence. The sync in your case will stop, if you would change the iCloud / AppleID-Account on one of your devices. Edited February 12, 20206 yr by Fabian1
February 13, 20206 yr Hi @SWFD Thanks for clarifying the details @Fabian1 As mentioned above, syncing and registration are independent. Also, I would like to share that you can change your registered email address if you wish. To do so, please go through this FAQ. Thanks.
February 13, 20206 yr Author Hi...thank you both for helping to clarify. I think I get it now. So if I also wanted to share a vault (for example with a family member) we would basically need to create another cloud account and dedicate that to hosting the shared vault? Thanks
February 13, 20206 yr Hey @SWFD Thanks for writing back. Yes. For more details, please refer to this FAQ. Let me know if you have any other queries. Thanks.
