February 27, 20206 yr Eighty percent of the time, when I try to sync, either manually, or through the auto sync, to my iOS devices through Dropbox, I get a failure message that says an error occurred. The error code is: 208056 Anyone know what this is? Thank you in advance for your help.
February 27, 20206 yr Hi, Sorry for the inconvenience caused to you. For quick troubleshooting, disconnect the sync from all the devices and reconnect it again. If your problem persists, please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Are you using any proxy/firewall?
