Enpass is crashing again and again and again...
I use Enpass on several platforms and I am a heavy user (I use it at least 20-50 times a day). On Windows 10 (latest Enpass from Store, latest patches installed) Enpass is crashing at least once a day - sometimes more often. Enpass- can you please spend some time and make this app stable? It is so annoying (really!) to restart the app all the time, especially if you're using a keyfile that you need to select each time the app starts (beceuase Enpass can not memorize the last used path for whatever reeason) and you have a long and complex passphrase to enter.
Please, plase. Make the windows app as stable as the OS X or Linux version!
Please share the crash report mentioning your name and the steps the reproduce the issue in the comment box so that we can investigate what could be the possible reason for the problem.
Thanks!
  • 4 weeks later...
I second that, very annoying and persistent bug. I send the crash report each time, but no improvement.
