March 3, 20206 yr Apparently keyfiles are required for iOS so I set out to make one using my Windows version of Enpass. That part was easy. I exited Enpass and restarted to test using the keyfile and it worked as expected. I then went to set up iOS and used the bar code to scan the keyfile. Upon submitting, the iOS Enpass app said that the keyfile was invalid. Hmm. So I went back to the Windows installation to poke around and see if I had missed something. When I went to refresh the sync to my vault it of course asked me for the keyfile that I had just made. I selected the keyfile and of course, Enpass says it's invalid. If I quite Enpass, type in my password and select the keyfile, it works. Syncing however no longer does and I still don't have it working on my iOS device. I'm in password purgatory. Please send help.
March 4, 20206 yr Hi @peron, Welcome to the forum! Please add the keyfile to your iOS device. To do so, please refer to this user manual. If the problem persists, please share the Enpass version and device detail along with the screenshot of the error so that we can investigate better. Hope this helps!
March 4, 20206 yr Author Hi. Thanks for the reply. That's the manual I was following. What worked for me was deleting everything and starting over.
