How to minimize Enpass to System Tray when click the X Button in UWP version?
Would you like to minimize Enpass to System Tray when click the X Button in UWP version?
UWP app always occupied one position in task bar, when click the "X" button, what I want is to minimize the Enpass window, but not close the App, just like traditional windows version.
Would you like to add such featuer in UWP version? Thanks in adv.
Hey @Angela-Wu,
Technically for any UWP app, it is not feasible to minimize them on click of close button. But we have noted your suggestion for implementation when the required APIs will be available for developers.
Cheers!
Hi, Akash
Thank you for your kindly reply, thanks.
So I can only wait.
