webdav sync with client certificate authentification failed
Hi there,
i use latest version of enpass 6.4.0 ( 631 ) on MAC OS Catalina. I am trying to configure synchronisation for WEBDAV ( owncloud ) but the connection failed.
We have done some changes to owncloud nginx configuration, you can connect to owncloud only with a trusted and valid client certificate.
The connection with webdav user to owncloud on my mac is working well. The certificate is trusted in my keystore.
The synchronisation on Windows 10 system with client certificate in the keystore is running well, without changing the connection parameter after changing the environment.
Has anyone an idea how to solve this on mac os ?
Many Thanks,
Regards,
Franz
H @Franz Ofner,
To investigate further on this issue we want a little input from your side so please perform these steps and let me know if the problem persists.
  • Download the debug version of Enpass from this link on your Mac.
  • Now open Enpass --> Settings --> Advanced --> Logs --> Enable it.
  • Now sync with WebDAV.When you receive an error --> Go to Advanced settings --> Logs --> Copy the Logs in any text editor and share with us.
Thanks for your co-operation.
