Sync Error 1208413 One Drive
Hi @phurd99,
Please try disconnecting the sync from all the devices and reconnecting it again.
If the problem persists, please share the following details so that we can investigate where the problem could be.
  • Total no of items and attachments.
  • Verify If there is space available on the One-Drive account?
  • Does the Date and Time setting set to automatic on all devices?
  • Does the last synced time get updated on the sync page?
Thanks!
What I have done so far.   Removed sync and enabled.   Deleted sync files on One Driver, and synced again.
Same issue across all devices.   Works on cloud sync.  This just started within the last month or so.
    Using on Mac Pro 10.15.3, Mac Pro Notebook10.15.3, ipad pro and iphone 11 13.3.1, Windows 10.  All have the same issue.
iPad and iphone 6.4.1 (445), On Mac 6.4.0 (632)
    838 items.  9 Attachments.
    Yes, Tons of space.
    Yes
    Not now, because it errors before ever completing a sync.
Issue resolved.     Reset all data on all devices.   Then did a restore on one and synced to One Drive.   Then on other devices did a restore from One Drive.   Working now.   Not sure what the issue was, but working now.
Hi @phurd99
Thanks for notifying us.
I have shared your inputs with the concerned team. It will be really helpful for them.
Thanks.
