Recent items
Recent items
I'm using the FF extension and it seems, that the list of recent items isn't updated correctly with the items I used at last. Especially when I type something in the search field and choose an item of the ones that are found, this one doesn't appear in the first place in the list of  the recent items.
Is it a bug or don't I understand how the list is created?
Thanks
Andreas
Hola @AzW
Thanks for dropping by.
Actually, the list of Recent Items comprises of the highly + most frequently used items. Based on this, a weightage is calculated for the items, so your newly used item will appear here after a couple of more uses. Thanks for intimating about this, and we'll improve the underlying algorithm in any of subsequent release.
Cheers!
