Updating passwords bug
I'm using Enpass with Firefox on OS X. When I change a password on a website there is a dialog that comes up to confirm which entry the password should be changed in. About half the time the correct site is pre-selected, but the "Update Password" button is greyed out. It seems that it is waiting for the dropdown box change event to enable the button, as once I change the dropdown to "Choose an item…" and then back to the correct website the button works as expected.
Hello @Ryan,
Thanks for reporting the issue. It will be resolved in the next version.
