August 11, 20179 yr Import from Lastpass incomplete Hi, I imported about 600 records from Lastpass-CSV (also tried txt). Yes, I before saved the files using UNICODE. Unfortunately after checking the imported records, I found a lot of missing information. Especially the secure Notes are imported incomplete. Is this a known bug of enpass? The exported files from Lastpass are correct and there seems nothing wrong. I tried importing to keepass and there is no issue with secure notes / no lost information... But I really would love it, using enpass!!!! Can someone help me? Thank you in advance! tom Edited August 11, 20179 yr by entom
August 11, 20179 yr Author Ok. I found out, how to do it: 1. LASTPASS export to lastpass.csv in unicode 2. Import lastpass.csv to KEEPASS 3. KEEPASS export to keepass.xml 4. Import keepass.xml to ENPASS Would be nice, if it worked directly...
