August 15, 20179 yr Hello, I just did a test with restoring backup files. And I got an error after using it (check picture). I'm using windows 10 with enpass 5.5.8. I don't have a problem now because I can always go back to a previous version of walletx.db with my own cloudserver. But maybe you can fix this problem for the next release? Edited August 15, 20179 yr by TREMOR
August 16, 20179 yr Hello @TREMOR That should not be happening. To look into it further I need some information from you. So please let me know: Does the app crash when you enter the master password or on just selecting the backup file? Do you face this problem frequently or on a certain instance (if yes, please explain a bit more)? Is sync enabled when you try to restore the file? Awaiting your response.
