enpass hotkey macOS 10.15
I can't figure out how to use the system wide hotkey. In the preferences window I read that this hotkey (for example smd-alt-#) lets enpass appear, whenever I press it. But doesn't. Nothing happens.
I also don’t understand how I can activate enpass in my browser (Safari or Vivaldi). There is the hotkey I can define, but it has no effect. Is there a general problem with Catalina? With Windows all works without any problem. And I beliebe, 1Password can do it also. But  don’t want to return to 1Password...
Hi @Podrageanu,
Please have a look at our user manual to enable the extension in the Safari browser. Once the extension is installed, you will be able to use keyboard shortcut using the shortcut, which you have set in Enpass browser setting. If you have any further queries, let us know.
