OneDrive sync fails after first successful sync
after ONE successful sync after connecting to OneDrive, Android app stops syncing with OneDrive.  After setting up the sync, it works fine one, but ALL further sync operations fail. I know this because the "Last synchronized" is the time when I set up the sync, and the "last attempt" keeps in changing, but "last synchronized" never changes after the first sync during the setup. AFter some time, Enpass starts to show error "Not able to connect to OneDrive. Please check Internet connectivity. Error Code:-113".
If I do DISCONNECT and reconnect it again works great once.
Enpass for Android is v. 5.5.6. Same issue occured on my Nexus 6P on Android 7.1.2, but also now on Android 8.0.
Edited by jpalo
Hey @jpalo
Sorry to hear about the trouble you're facing. We are already aware of this issue and our dev team is looking into it. Meanwhile, please use any other cloud service to sync.
Till then please bear with us.
  • 3 months later...
I am still having a problem with OneDrive sync. It works once then always fails. Have you any news about this issue?
Thanks,
John
  • 1 month later...
I am planning to use OneDrive as well, is this problem already resolved? Thanks
