April 26, 20206 yr The icon on my Windows 10 installation is just a white keyhole. I can't find the executable to change the icon like in other normally installed programs. I'm trying to change it to the website icon... white keyhole surrounded by a blue circular background. Any help would be appreciated Thanks
April 27, 20206 yr Hi @Wingfat, Sorry for the inconvenience caused to you. Currently, there is no option in Enpass to change the program icon in Store or Website version. However, we have noted down your request and forwarded it to the concerned team for further consideration. Thanks for your feedback!
