April 28, 20205 yr If I copy an Enpass generated password to my clipboard it does not persist in the Windows clipboard history (Win + V). I understand the concern about not copying into the cloud clipboard but that should be my choice whether or not to persist into my clipboard history. It's quite a hassle if I want to use that generated password beyond the next thing copied into the clipboard. It forced me to have to open up Notepad and immediately paste into there so I don't loose it.
April 29, 20205 yr Hi @sdunnin, Thanks for using Enpass and writing to us. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
