May 16, 20206 yr I can easily move items between vaults with the Windows and Android apps, but can't seem to get this done with the iPad app. Is this supported?
May 18, 20206 yr Hi @gmill99, We are sorry for the inconvenience caused to you. If you are using Enpass pro/premium version, you can have multiple vaults and move the items between them. Please let us know are you able to create a new vault on your iPad.
May 18, 20206 yr Author I have Enpass pro with multiple vaults already set up. How does one move items between vaults using the iPad app?
May 19, 20206 yr Hey @gmill99 Thanks for writing back. Please refer to this link of user manual to know the steps of doing so. Hope this helps!
May 20, 20206 yr Author I read the docs before starting this topic. The Android app works as described, the Windows app requires a right click, not a click on the three dots menu, but functionality is still accessible. I must be missing something obvious, because I cannot find the UI to move an item between vaults using the iPad app. Can you post a screenshot showing this?
May 20, 20206 yr Hey @gmill99 Thanks for writing back. Please find the attached screenshot in sequential order for your reference. Hope this helps.
May 21, 20206 yr Hey @gmill99 Thanks for notifying us. I'm glad to know that the problem has been resolved. Thanks!
May 24, 20206 yr Hi, my "Add to Vault" Button is greyed out. I too, have the pro version. Please advise.
May 24, 20206 yr 31 minutes ago, imsnd701 said: Hi, my "Add to Vault" Button is greyed out. I too, have the pro version. Please advise. I found the answer. I was not able to move to a different vault during a "search." I don't understand why I can't move items that I searched for.
May 25, 20206 yr Hi @imsnd701, Thanks for writing in. Unfortunately, from your comment, we could not quite understand what problem you are facing. Please share some more details so that we can assist you better. A screenshot, if possible would be great.
