[SOLVED] enpass often crash after I wake it up from the background?.
Hello,
A crush problem is occasionally occur on my iPhone7 (ios10.3.3) and certainly occur on my iPad (ios 10.3.3) as follow,
first, I opened the Enpass and closed it to home screen. second, I arbitrarily opened another app, then I double click the home button and wake up Enpass from background.
And Enpass just display a white scene with a lock, no other response show until the Enpass crashed and quit.
This problem often breaks off my operation, because I have to wait and reopen Enpass.
I want this problem will be quickly resolved.
thanks
iosman
Hi @iosman001,
Please let us know which Enpass version are you using on both the devices so we can further investigate this issue.
Thanks for your co-operation.
On 5/17/2020 at 1:23 PM, iosman001 said:
Hello,
thanks
iosman
thanks my issue has been fixed.
  • semi_mod changed the title to [SOLVED] enpass often crash after I wake it up from the background?.
  • semi_mod locked this topic
