September 1, 20179 yr Use wildcards to urls Hi i have a suggestion for the autocomplete. I have saved the login credentials for the desktop version of a site e.g. (www.facebook.com) when i try to login from my phone it gives me the mobile version of the site (m.facebook.com) and enpass cannot find the login credentials. My suggest is that the autofill to be able to recognize and use wildcards for the url e.g. (*.facebook.com)
September 27, 20179 yr I would go even farther than that and easily allow us to add several urls to a login entry, some company leverage "SSO" to let you connect with the same set of credentials on multiple, very domain names, for example amazon.com and amazon.de share the same login backend. Right now it will store one entry for each website and will get out of sync as soon as you change your password as only one entry will get updated. Once implemented, we would then need an easy way in the UI to "merge" two entries, and maybe ask the user which password to keep if the passwords are not identical (most probably because one of the entries still has the old password before a reset). I don't know any password manager that handle this use case in a nice, user friendly way and this would be a great plus to Enpass.
May 13, 20251 yr This post is from 2017. Was this feature ever implemented? I was trying to add a wildcard port number. I develop websites, so https://localhost:* comes up a lot.
May 20, 20251 yr We are looking into the issue with the technical team and will follow up with an update soon. #SI-4371
