May 20, 20206 yr Hallo, I have been using Enpass for many years, now have fully functioning iMac and MacBook Pro using 6.4.2 and syncing with Dropbox On iPhone XR and iPad Pro, am now unable to sync Enpass with Dropbox. I know the passwords for enpass and for dropbox, but each time I attempt to open iPhone/iPad, I'm advised the sync to dropbox requires master password. Have repeatedly tried to use the correct pw used on iMac without success. I have deleted the app from iPhone, reinstalled and it won't accept the passwords. I have tried to reset the master password for Enpass and on entering the correct pw to provide it's me, I'm repeatedly advised it';s the wrong master pw. Fix suggestions please - app is now deleted again. Thank you.
May 20, 20206 yr Hey @Sim Goldblum Welcome to the forum! Please follow these steps, as mentioned below: Disconnect Sync from all devices. Open Dropbox on any browser on your macOS-> Go to App> Enpass folder> Vault.enpassdbsync -> Rename it as Old vault.enpassdbsync. Now open Enpass and enable Sync on the macOS. Now restore the data on your iOS device using cloud restore and then set up sync. Hope this helps!
May 31, 20206 yr Author Thx Garima, I thought it had worked.... On the iPad, we had success, but now, when I look at settings, I am asked to set up sync again, only this time, even though it connects to dropbox (using the same pw.used on OS)), it states the sync error password of data on Dropbox is required . On the iPhone XR, I had previously deleted the app. So I reloaded it from App Store and it has noewasked for pw of data? What is that (for both iPad and iPhone? Now, the MacBook Pro won't function - it won't accept the master password that worked on the other 3 devices! I hope you can find a solution for all devices! Thanks Sim Goldblum
June 1, 20206 yr Hi @Sim Goldblum We are sorry for the inconvenience caused to you. For quick troubleshooting, disconnect the sync from all the devices and reconnect it again. If your problem persists, please share the following details so that we can investigate where the problem could be. On which all devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? On which device and OS version are you getting this issue? Are you getting any error message or code during sync? If yes, share the screenshot with us. Does the Date and Time setting set to automatic on all devices? Does the last synced time get updated on the sync page? Thanks!
June 4, 20206 yr Author Thank you. Disconnected and reconnected on iMac and MacBook Pro (running OS 10.15.4 10.15.5 respectively). Both working with Enpass 6.4.2 (688) On iPad Pro and iPhone XR, running Enpass Pro All access (Lifetime) 6.4.4, Ib can setup sync, obtain approval from dropbox and then I'm asked for password of data - see screenshots from iPhone and iPadPro. I have tried using the dropbox pw and the Enpass pw and neuter work. I do not know what this pw is. I look forward to your fix! Sim
June 5, 20206 yr Hey @Sim Goldblum Sorry for the trouble you are having. Please use the same password which you have used to sync the database setup previously and share your findings with us. Thanks.
June 8, 20206 yr Author As I stated in my earlier post, I have tried the Enpass master pw and the dropbox pw. I do not have any record of another pw
June 8, 20206 yr Hi @Sim Goldblum, Sorry for the trouble you are going through. Please update your Enpass app on all the devices to the latest version and let us know if it persists.
