1pif import doesn't work
Hi there,
I'm trying to import my 1password data file but it's greyed out and can't be selected.
Does anyone know how I can fix that?
Thank youi
Hey @Maya
Welcome to the forum!
Please make sure you have only opened the home/front page of the Enpass app and then click on the file option from Enpass Menu. If the problem persists, please revert back to us.
Thanks!
Hi Garima,
Thank you, I just figured out what I did wrong. I was trying to import the .1pif file instead of the .1pif folder.
They both have the same extension so that was a bit confusing. Importing the folder worked now.
Thank you,
Anja
