May 22, 20206 yr Hi, could you please add features to delete predefined categories delete predefined templates alter templates It is really annoying that one can't do that. Cheers, Paul
May 25, 20206 yr Hi @Paul Förster, Welcome to the forums! We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Meanwhile, you can create a custom template that is available in the Desktop version of Enpass. For more details, have a look at our user manual. Hope this helps!
December 1, 20205 yr I'd liike to concur with this. Plus be able to scroll down the list of templates (takes quite a bit of effort to see bottom) beiable to stretch length/width of template in edit mode (creating) be able to name sections
December 3, 20205 yr Hey @macRBC Thanks for letting us know that you would like to see this. We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The same has been noted and shared for further consideration.
December 4, 20205 yr On 5/25/2020 at 1:52 AM, Pratyush Sharma said: Hi @Paul Förster, Welcome to the forums! We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Meanwhile, you can create a custom template that is available in the Desktop version of Enpass. For more details, have a look at our user manual. Hope this helps! I've posted my question regarding custom templates.
December 8, 20205 yr Hi @macRBC, Thanks for writing back. Currently, there is no option to delete predefined categories/templates. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration.
