CSV Export
CSV Export doesnt use all Fields
Hello,
there is a bug in the csv export. When im adding new Fields and fill them with Informations, they doesnt show these entrys after export as csv File.
-> I need all Headers.
How can i change the Template for new Logins? I need the field SYS-ID in every new Entry. Is it possible to add my Custom Field "SYS-ID"  to the Standard Fields when i adding a new Login?
Greetings
P.Bluhm
Edited by pbluhm
