May 25, 20206 yr I have installed Enpass on Macbook pro. I also have an iPhone and iPad. Do I have to install Enpass on these 2 devices to be able to access the password vault on them?
May 26, 20206 yr HI @Ian J, Thanks for using Enpass and writing to us. Enpass is an offline app. We don't keep any of your data as it's saved locally on your device, not on our cloud or servers. Moreover, the app doesn't require any sign-up. So to use Enpass on any other device, you need to install Enpass separately on each device. After successfully install, you can restore data using cloud sync.
