May 26, 20206 yr Enpass auto fill not working for gmail login, using chrome. Auto fill option turned on in browser settings, had to manually copy paste.
May 26, 20206 yr Hi @pratheep, We are sorry for the inconvenience caused to you. Please revert to us with the answer to the following queries and we will get it sorted out for you: On which device (along with OS version) are you using Enpass? Which Enpass and Enpass extension version are you using? Which Chrome version are you using? Are you facing the same problem with other browsers too?
May 26, 20206 yr Author 20 minutes ago, Pratyush Sharma said: On which device (along with OS version) are you using Enpass? -- Laptop(i5 8th gen Quad core 2018 model)\Windows 10\ Enpass 6.4.2(662) - from store Which Enpass and Enpass extension version are you using? -- Enpass 6.4.0 Which Chrome version are you using? -- Version 83.0.4103.61 (Official Build) (64-bit) Are you facing the same problem with other browsers too? -- yes, tried Brave & Edge(Chromium) Hi @pratheep, We are sorry for the inconvenience caused to you. Please revert to us with the answer to the following queries and we will get it sorted out for you: On which device (along with OS version) are you using Enpass? Which Enpass and Enpass extension version are you using? Which Chrome version are you using? Are you facing the same problem with other browsers too? Edited May 26, 20206 yr by pratheep
May 27, 20206 yr Hi @pratheep, Thanks for sharing the details. I have noted down this issue and notified the QA team to look into it.
