May 27, 20206 yr I'm using the latest v6.4.2 (667) on MacOS and TOTP codes seem to have stopped working. They works well on the Android app. The same thing happened in the past and was fixed with an update. Is it happening again?
May 27, 20206 yr Hi @Javier, Sorry for the inconvenience caused to you. Please make sure that date and time are accurate on all devices (preferably set to automatic) and If the issue persists let us know. Hope this helps!
May 29, 20206 yr Hi @Javier, Thanks for notifying us. I'm glad to know that the problem has been resolved.
